Creo 6 on Windows 11
awkwardcj
2-Guest
Hello Creo community!
I am currently running version 6.0 on my laptop for my solid modeling class. However, the new Windows update has come out and I am afraid it may no longer work if I upgrade, so I would like to ask if it's safe to upgrade to Windows 11 for version 6.0.
Thank you all so much in advance! I really appreciate the help!
Here is a - "Creo Future Platform Support Summary": https://www.ptc.com/support/-/media/7D1BD5F82F7B483C90454DE134F29D8E.ashx?sc_lang=en
Thank you Vlad! I had looked at this .pdf before and it did not mention the 6.0 version, so I wasn't entirely sure if I was looking in the right place.
You're welcome.
You can use the PTC Calendar to check compatibilities.
Creo 06 is not compatible with Windows 11.
Article CS348041:
Older versions of Creo Parametric are not tested and hence, not supported on Windows 11 platform
Please refer to Creo Future Platform Support Summary
Creo 7.0.7.0, Creo Parametric 8.0.3.0, Creo Parametric 9.0 and later are supported on Windows 11.
See Creo 8.0 Hardware Notes
See Creo 7.0 Hardware Notes
