Currently there is an understanding that a trace/link between two data objects can be created through a drag and drop. Is there any other functionality within the tool that uses this drag/drop? (other than standard windows functions like moving files or attachments)
Hello Todd,
Document model uses drag and drop (sometimes with modifier keys) to copy or moving content between documents. If a relationship is correctly defined between types, traces can also be linked in this way.
Files can also be dragged into attachment fields in the client.
Kael
Hello Todd,
Kael
