How can I configure a sandbox scope like "path:AAA OR path:BBB OR name:frolic.txt"?
The Help file for the 2009 MKS Integrity GUI says that the "si configuresandbox" command can be used to implement scopes using a combination of logical AND or OR operators, but the si manpage we have doesn't seem to mention --scope and the help text from "si configuresandbox -?" indicates some syntaxes like "name:value" and "path:<expression>" with no hints about how to apply logical operators.
Pointers to documentation I missed are appreciated!
Barrie
Hi Barrie,
the best description you can find is in the SourceCLIReference.pdf described in commands "createsandbox" or "configuresandbox".
“OR”- combination of scopes of the same type is done with comma. E.g.
--scope=name:*.c, name:*.h, name:*.xml
“AND”- combination of scopes is done with a new scope. E.g.
--scope=path:/030_Software/* --scope=name:*.c, name:*.h
Please Note:
You cannot set a combination of scopes via the client GUI (due to a poorly programmed dialog). All "advanced" scope settings must be done via the CLI.
“NOT”- inversion of a scopes of the same type is done with “!”. E.g.
--scope=!name:*.zip
HTH
Matthias
Hi Barrie,
Please Note:
--scope=!name:*.zip
HTH
Matthias
Thanks, Mattias.
I checked that PDF prior to posting; the copy at http://www.mks.com/support/productinfo/docs/SourceCLIReference.pdf does not mention --scope.
Is it possible to do "(path:AAA AND name:frolic*.txt) OR path:BBB"?
Also, is there any quoting mechanism for whitespace or colons in filenames?
Seems like allowing "||" and "&&" or similar in the scope <expression> would be useful.
Thanks again!
- Barrie
Hi Barrie,
I took a quick look, and couldn't find anything references to --scope before
Integrity 2009 SP6, in which the Source CLI Referece for Integrity 2009 SP6 Guide does contain a good explanation under si createsandbox on page 62. Make sure that the service pack you are using supports the --scope option. I do not believe it was a valid option in Source Integrity 2007. Regards, Kael
Thanks, Kael. We are running 2009 and the --scope option works as Matthias describes.It's surprising to me that the main one on the web site is apparently years out of date.
Thanks again, I'll see if IT can get me an updated guide.
- Barrie
