Automatic creation of subsection below a heading in documents
mzerle
11-Garnet
Is it possible to do a setting which automatically moves a comment or requirement below headings?
Target is to have a document structure similar to a word document. Level / section 1 only headings, section 2 for requirements and comments.
Thank you
Markus
skamaraj
11-Garnet
(To:mzerle)
If the hierarchy is based on heading style (H1, H2,..) then it will be more flexible and pleasant to look. By this way, the entire document will be structured, with sections -> sub sections -> sub sub sections and so on.
Integrity knows the item category only when it is saved. So this sectioning has to be performed during saving an item.
If their is a possibility of this trigger slows down the operation, then a menu shall provide to "Format Sections" of entire document. This is almost similar to doing format of HTML/XML source code 🙂
Sathish
Hi Markus,
This is possible using Triggers but somewhere you need to define under which heading the comment / requirement should move to.
Neeraj
