CLI - si co command on version11.1 fails on missing local project.pj
ilampe
For example
in older Integrity version the
command below worked correct  but failed in Intergrity version 11.1 because of missing local project .pj.
Projectpath=/Projects/Library/LibPart1/project.pj
Sandboxpath=C:\Library\LibPart1
working path cmd-line C:\Library\LibPart1
si co --hostname=... --port=... --nolock --batch --yes -S c:\Library\LibPart1\project.pj c:\Library\LibPart1\*.*
if Sandbox location is the same as project location it worked, otherwise not.
For new versions since 11.1 worked only on same pathes (project path and sandbox same hierachy):
si co --hostname=... --port=... --nolock --batch --yes c:\Library\LibPart1\*.*
error Message:
Checking out...
*** MKS125408: c:\..*.* is not a valid member name.
Can anyone show me a solution how i can checkout the files in the sandboxfolder in version 11.1?
I hope to get help here
Thank you
ingo
3 REPLIES 3
MichaelChatel
20-Turquoise
(To:ilampe)
Hi Ingo,
I'd suggest opening up a Support case with PTC Integrity support, as they should be able to assist you with this.  I'm not sure exactly what you're trying to do based off your posting here, as it's not that clear.  I don't see any "si co" command in your examples here.
ilampe
(To:MichaelChatel)
on changing the original pathes  and  host and port i make a copy past error.
I have corrected it.
MichaelChatel
20-Turquoise
(To:ilampe)
If you're trying to check out everything, the "si co" command does not accept *.*
If you don't specify a membername, then the command applies to all sandbox members, which it sounds like, is what you want.
