Can an href open an edit window?
smccoy
Our users would like the ability to open an edit-window based on an href. Is there something that we can add to the query string that will only the editable version of a window instead of the read-only window?
Example:
We have this working to open a read-only window for an item.
<a href="integrity://localhost:7001/im/viewissue?selection=12362">
We are looking for something like the following to open an editable window:
<a href="integrity://SPA-CL-B34FYW1.corp.irco.com:7001/im/viewissue?selection=12362,edit=1">
Is this possible? And if so, what is the syntax?
-Sean
LLawton
(To:smccoy)
The command for http is simply "editissue", but it doesn't work with url: integrity.
The message I get is: MKS154477: Command "editissue" is not supported for use in Integrity URL links.
LLawton
(To:smccoy)
smccoy
(To:LLawton)
Thank you for the quick response. I'll enter a case number to get an RFC created for this. Hopefully, we're not the first to request this functionality.
-Sean
Hi Sean,
For your information, not all href functionality that works against the Integrity server with an http protocol works against the Integrity server with an integrity protocol.
There is a similar feature request for im createissue with integrity://. You might want to point that out in the ticket you open, as it is likely closely related functionality.
Kael
Kind Regards,
Kael Lizak
