Can anyone tell me CLI command about "How to insert deleted content to same document again" ? or is there any other method to do the same ?
kjain-2
Unfortunately, as you see in this discussion, there is no such command or method.
If we could edit the Contains/References relationships, we could do it but we can't.
Please vote on the idea linked to by Adriaan in the linked discussion above.
kjain-2
(To:LLawton)
Hi Laurent,
Thanks for your input. I am also with you that we can't edit contains field so it's not possible at anyhow. And i have noted this issue and vote an idea for the same.
Thanks Laurent.
Kapil
