Can anyone help me out to get the ID of the very Last item present in Integrity? We have a workaround, that is create an item and the ID returned is the Id of the Last item in Integrity. But the restriction is, I dont want to create an Item in Integrity.
Run a query for items created e.g. in the last 2 days and sort the result by Creation Date
The ID of the youngest Item should be the one you seek.
Thanks A Lot! It worked & helped! ![]()
