Create query or search for baseline labels in PTC Integrity documents
EM_10182014
Use Case: For example, I want to know which software specification documents, software design documents, etc., have a baseline label equal to 26WL_IPC_R1
Description:
I wonder if creating a query or searching for all documents with a baseline label of a certain value in PTC Integrity 11.2 is possible.
I don't see baseline labels stored in fields that allow me to create a query or search for certain baseline label value.
Edgar
2 REPLIES 2
Hi @EM_10182014
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • Do you know where the baseline labels are stored within PTC Integrity? Are they associated with specific fields or metadata?
  • Are you looking to search for specific types of documents (e.g., software specification documents, software design documents), or should the query include all document types?
  • What search capabilities do you currently have in PTC Integrity? Are you able to create custom queries or use advanced search features?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
aseifert
(To:EM_10182014)
Hello Edgar,
baselines are basically labels and its search is documented within https://www.ptc.com/en/support/article/CS293906
When you check your document Labels tab you will see Baselines mentioned as "Baseline: Delivered" for example.
As the search does not support fuzzy searching and needs exact value (as shown in Labels tab), your example would require a search for "Baseline: 26WL_IPC_R1"
Hope that helps.
Kind regards,
Andreas
