Delete labels created by trigger Segment State?
nxpet
Hello everyone,
we changed or document workflow. Now I want to delete some of the labels which were automatically set by trigger "MKS.ALM: Segment State". For each state defined in MKS.RQ.BaselineLabelStates a label in the form "Baseline: Published" is set, when document comes into that state.
I tried to deleted such a label, but I get the following error message:
MKS124803: Internal error detected: Exception was: java.lang.NullPointerException
Is it possible to delete these label afterwards?
Timo
nxpet
(To:nxpet)
Ok, I found the problem in an article, but I haven't tried it yet: Baseline.js needs to be adapted according to CS89970 to allow this operation.
 Edit: solution works for me as described in the article
1 REPLY 1
nxpet
(To:nxpet)
