Edit in Word - how can I change the styles
tstenroth
Here is my situatioin: I open a document to the Word using Edit-in-Word functionality. There are default styles shown in the inline view of Word. If I make changes to these styles and reopen the document again to the Word, all the changes that I made are overridden by the default styles.
Where can I found these default styles? Where is the style file located?
Hi Terhi,
the available and used styles are defined in the Edit-In-Word-Template file your administrator had set for the item type in your integrity setup.
BTW:
Please keep in mind that Integrity uses xhtml to store the rich text data. therefore you cannot expect to have all the styling options you have in Word.
Ask your local Integity Admin for Details
Hi Terhi,
BTW:
