When we have many menu items, not all menu items are shown up, and we cannot select some menu items.
<More specifically>
If we use a laptop PC of B5 size, only 30 menu items are shown up on the screen, and the 31th item are half-shown, and we cannot see the rest of items.
If we use a laptop PC of A4 size, only 33 menu items are shown up, and we cannot see the rest of items.
If we encounter such a situation, we have to switch over to the another menu, this is cumbersome and time-consuming.
We want to have a vertical scroll bar as depicted below.
Hello 用華 李,
This might be covered by SPR 5342328/CS86060. I can't tell, because I'm not sure the menu items match up, but the screenshot looks similar. Even if it's not the same, it might be similar. Could you open a case with PTC Integrity Support to investigate that, and potentially get yourself added to the defect?
Kael
Hello Kael Lizak.
Thank you very much.
My request is the same as CS86060.
We expect a resolution.
用華 李(YongHwa Lee)
