I need to know the projectType of projects in a sandbox, (meaning if they are build or normal etc.)
Until now I could use the command "si sandboxinfo --sandbox=... --xmlapi"
With Integrity 10.7 --xmlapi has been discontinued and using the same command without --xmlapi doesn't seem to give me the projectType.
Which command should I use for this matter?
Thanks in advance,
Luca.
you are right, the --xmlapi is no longer present in 10.7 (why
For your case there is a simple solution, you don't need the --xmlapi.
Look in the first line of output from si sandboxinfo:
for normal sandbox: Sandbox Name:
for Variant sandbox: Variant Sandbox Name:
for Build Sandbox: Build Sandbox Name:
i hope that helps ![]()
alternative you can use the java api....
