Get working revision and if modified by CLI
tdalon
Hello
Is there a way by command line to get the working revision of a file in my sandbox and if it was modified from the original revision (means appear with Diff in the Sandbox View)?
Many thanks
Kind Regards
Thierry Dalon
tdalon
(To:tdalon)
Using si diff with --xmlapi I could workaround the hanging issue for binary files.
(The --quiet flag does not work as expected here).
The final solution looks like this:
%Get working revision using:
si revisioninfo --revision:working $file
% Get diff status using:
si diff -r wrev --xmlapi $file
% Parsing the xml output to get the status
3 REPLIES 3
tdalon
(To:tdalon)
I've found a solution using
si revisioninfo --revision=:working $file
and
si diff
tdalon
(To:tdalon)
I have an issue with the si diff command on a binary file. It hangs.
Does anyone know a workaround?
tdalon
(To:tdalon)
