How the database or data is defined in PTC RV&S application.
AarushiS
In RV&S application, what data schema does the application follows and how the data is defined in backend?
1 REPLY 1
Hi @AarushiS
Thank you for your question.
It appears that your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Best regards,
Catalina
PTC Community Moderator
PTC
