How to count the RQ's Text field's with specific text in report?
Chittaranjan_11
I have 10 requirements in a document having short text field with various values
"free text" is a name of field which is of short text type and available on Requirement Type
Ex. there are 5 RQ's are having free text value is Black,
Que: How to count the REQ's which are with Black value free text ? the count is needed on Report's computation.
REQ 1  --> free text = Black
REQ 2 --> free text = Black
REQ 3  --> free text = Green
REQ 4  --> free text = Yellow
REQ 5  --> free text = Red
REQ 6  --> free text = Black
REQ 7  --> free text = Black
REQ 8  --> free text = Pink
REQ 9  --> free text = Green
REQ 10  --> free text = Black
I tried with some aggregate functions,
Count of Req's having free text value --> possible, But how to count with specific text ?
aggregate("Contains", ByDocument(false, false), sum((Category="Functional Requirement" and SelectionCount("free text")!=0)?1:0))
2 REPLIES 2
kjain2
(To:Chittaranjan_11)
Hi @Chittaranjan_11
Try this:-
IsEmpty(aggregateByTree("Contains", References,sum(Category == "Functional Requirement" and "free text" == "Black" ? 1 : 0)), 0)
Or if that doesn't works:-
- Refer Help Material "Computed Expression Function Classes" page, there you will see all possible computation.
- If computation doesn't work at all for any reason and you need only this count in report (HTML page) use JavaScript in report code and you can count on the fly    and display where ever you would like to display. (This will not work if you want to show count in Integrity Item also this is only for report page)
Does this help?
Vielen Dank / Many Thanks
Kapil Jain
Chittaranjan_11
(To:kjain2)
The provided workaround IsEmpty(aggregateByTree("Contains", References,sum(Category == "Functional Requirement" and "free text" == "Black" ? 1 : 0)), 0)  is not working.
Also as i checked in the manual "Computed Expression Function Classes" we cannot get anything for text value attribute.
