How to use the field value of type FVA (with possible return values integer 0 or 1) to use inside a 'logic' field with computation check? In short FVA field values could be 0 or 1 only and they need to be trnasformed to present boolean values true or false for logic field.
Hi @AN_10548594
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. For example:
It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
