How to get boolean from FVA inside computation area?
AN_10548594
How to use the field value of type FVA (with possible return values integer 0 or 1) to use inside a 'logic' field with computation check? In short FVA field values could be 0 or 1 only and they need to be trnasformed to present boolean values true or false for logic field.
Regards
Hi @AN_10548594
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. For example:
  • How is the FVA field currently configured in Windchill? Is it set up to return integer values (0 or 1)?
  • What specific logic or computation do you need to perform using the boolean values derived from the FVA field?
  • Are you looking for a built-in method within Windchill to perform this transformation, or are you open to using custom scripts or code?
It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
