How to import/update Parameter Name/Value to PTC Integrity document with CLI?
Chittaranjan_11
How to import or update Parameter Name and Parameter Value to PTC Integrity document with the help of CLI?
Ex : If I want to import 20 parameter values at a time via CLI.
Hi Chittaranjan,
I have written a small script to copy parameters from one item to another, will this help you?
Volker
2 REPLIES 2
Hi Chittaranjan,
Volker
Sure, you could share it.  I will check it, and you mean it could be possible to copy parameter and values from one document to other document?
Will it be possible to update the parameter and values from excel so we can able to upload in the bulk
