Hi, I am facing issue with connecting with server, using centralize server for licensing. can any one face this issue before?
Hi Pradeep,
There is not enough info to know what issue you may be hitting with your Integrity 11 and Flex license server, so if you can provide more info, that would help. What shows up in your server.log file, for Integrity server? Is this a new install, or an upgrade?
Note, for Integrity 11, it's required to install the newer version of Flex, that comes with Integrity 11, so if that hasn't been done, that could be a reason you're having issues. Also, you would need to make sure both lmutil.exe and mks.exe (the vendor daemon) have been copied to the correct Flex location.
I suggest opening a Support case with the relevant details, and Support should be able to help identify what issue you are hitting.
Thanks Michael, i have few queries regarding licensing issue.
I am using server license maintaining it using is.properties file, still do i need to install FlexNet and configure?.
If am able to ping the license server than what will problem with connecting to server?.
I'll open the support ticket for it but i am not able to understand these few points.
Thanks again for guidance.
Hello Pradeep Wadwalkar,
You'll need some sort of FlexNet configuration. If the FlexNet server is compatible with the Integrity server, you can install the MKS daemon on a new port of that server, and refer to that FlexNet server with a redirector license, rather than doing a new install. See CS127296 for more details.
Kind Regards,
Kael
Hello pwadwalkar,
It looks like Kael's solution fixed your issue; would you please take the next step and mark his answer as "Correct Answer?"
This way others reading the thread know there is a solution, in addition, it makes the solution easy to find.
Thank you,
Adam
