I'm getting the following message:
Communication to remote system failed with a return code of 530.
Where do I find a listing of what the return code means?
Likely causes for a 530 return code:
This typically means that MWIPROD does not have the authority it needs.
If you go to our website and search our knowledgebase for 530, you will see an article that explains exactly what MWIPROD needs.
There is no list of return codes, as they typically can mean multiple things.
Hope this helps. If not, please log a case with Support and they will help.
The 530 error is probably coming from the FTP file transfer process.
You can change the IMTSTMOD data area to '*MSG' and re-run the promotion ... a transcript of the FTP conversation will be sent to the joblog. This will give you information about the specific function, that was being executed through FTP, that is failing.
Thanks, the issue was the password was set to *NONE.
