Hi, I have recently installed a standalone version of PTC Windchill (v8.5 formerly known as IM) in order to check a model received and then export it for use in the latest PTC Windchill product. I have the enabler service running and can currently see an Example and Model repository.
I was delivered a .SAV file in a SAV.ZIP file. I am unable to import the .ZIP (no model information) from PTC IM and unable to see how to Recover the .SAV file (unzipped) using Repository Administrator (running in administrator mode). Can anyone please help by instructing me how to load the model into a repository? Many thanks 😓
Please check below knowledge articles,
Hope this helps.
Hope this helps.
Very many thanks, the second article was perfect. Recovered successfully.
Glad it worked!
