Hi all,
it is possible to insert/include versioned(!) documents in a document?
If I select a versioned document in the finder Dialog, the OK button is disabled...?
It is possible to configure? Or should be possible in a upcoming version of Integrity?
thx
Bernd
IMHO this is not possible
(at least in 10.6)
but I would love to see this implemented, as it is THE MAJOR use cases for versioned documents (in our company).
(at least in 10.6)
seems that we have a similar use cases
May I ask whats your work arround?
Our thought was to include smaller versioned subdocuments in to a parent document. Then,this document should be baselined.
Now we have to use branched documents, I think .....![]()
We have 10.5
from my perspective the only "pure document" solution is branching.
A branched document can be added to any other as subdocument.
But, if you just like to create a reference, you can create a new relationship field and can reference any live document and/or versioned document.
Unfortunately, then the word export will not work as expected.
I am sure a future Integrity relase will handle this better.
Volker
I concur with Volker: as of 10.7, branching seems like the best way to deal with your use case.
Having said that, I believe you both feel strongly about this, and I can certainly see an argument for your use case. Please file a feature request for this with Integrity Lifecycle Management Support.
Kael
To close the loop on this: This functionality is covered by RFC 972638. Please file a feature request to be added to this RFC by opening a case with Integrity Lifecycle Management Support.
Kael
Hi Volker,
thanks for your help
I believe it's very relevant. We're struggling with the same.
Since the RFC's seem to be abandoned, I created it in the Product Ideas section. Insert/Include versioned documents
I suggest you vote it up.
