Integrating PTC with serviceNow
SB_11705253
2-Explorer
I want to integrate serviceNow with Ptc. So that i can get the license details, allocation and usage time.
Articles:
Articles:
Hello @SB_11705253
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
nimish_gopal
(To:SB_11705253)
Hi @SB_11705253
If you're looking to integrate PTC data into ServiceNow for insights on license details, allocation, and usage, below are the options:
  • Use Windchill PDMLink native tool:
    • You can sync data between PTC and ServiceNow, but it relies on webhooks, which can be unreliable and not for enterprise use. Also, you will need to write code for integrations and any tweaks.
  • Use enterprise grade integration solution: OpsHub Integration Manager (OIM).
    • No coding required! You can easily configure field synchronization while also syncing comments, attachments, images, relationships, and history.
OpsHub  a ServiceNow & PTC partner, provides bi-directional synchronization with predictable outcomes, scalability, robust error handling. Feel free to reach out to our  iintegration experts for an initial free consultation on integration planning.
OpsHub team
