Is it possible to take presentation template from one system to another like we have created a presentation template on one system and we want to use that as it is on another system. Is there any way to do this??
kjain-2
alabonte
(To:kjain-2)
kjain-2
Thank you for your inquiry into Copying a Presentation Template from one Database to another.  After some research, it seems that our knowledgebase article CS150609 is very similar, and has successfully assisted other customers with the symptoms described by your issue.  Please let us know at your earliest convenience whether this article does in fact provide a solution to your predicament.
Most Respectfully,
Adam Labonte
alabonte
(To:kjain-2)
kjain-2
Most Respectfully,
Adam Labonte
kjain-2
(To:alabonte)
Hi Adam,
very first a big thanks to you. I reviewed knowledge base article that you suggest to me and its worked. Its just a two step process just we have to run two queries from CLI to deploy/move presentation template form one system to another just we have to careful about fields that we are using because it should be mapped in both the system/database otherwise we have to just do some modifications but not a big deal. Its very efficient way. Thanks
Kapil Jain
