Is there a way to create a SI project in Web UI
agupta-2
I did not find any option of creating a project in SI. Also not able to find it in help.
Any idea on this?
2 REPLIES 2
Hello Aashima,
It is not possible to create SI projects in the Web UI. Your options are to use the thick client, the command line (possibly via the API through com.mks.CmdRunner), or via a trigger (through the beans ScriptNewProjectArgumentsBean and ScriptNewSubProjectArgumentsBean).
Kael
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
Thanks kael for your help ...
