We want to connect MKS2009 Server with Jenkins 2.3.
Which plugin-revision is compatible with our "old" MKS 2009-Server ??
MKS2009 isn't supported with the current Jenkins integration and R&D has never tested/certified the same. A suggestion would be pick up one of the earlier builds of the plugin hpi from here and install it on your Jenkins environment. You could do a test run with versions 1.9 (or below).
