After installing WindChill Client 13.1.0.1 i have on some PC the problem the createCmdRunner command give me a com.mks.connect.HttpCmdRunnerImpl instead of com.mks.connect.ClientCmdRunnerImpl.
The result is this Errormessage as soon as i want to call a execute on this runner:
Connect to 127.0.0.1:31000 [/127.0.0.1] failed: Connection refused: connect
The question is now why do i get with the same code different runner on different pc?
I have the same problem. If you find a solution, please share it.
