Open the Project view in Integrity Client GUI with a file member highlighted ?
amatei
We are using Integrity 10.8
Is there a trick to open the Project view in Integrity Client GUI with entire project content visible and just one file member highlighted in the tree ?
Currently it seems that this is not possible, by using the URL below, just one file member is displayed and everything else is hidden.
integrity://server:port/si/viewproject?project=ProjectPath&selection=FileMemberName
I want all the project content visible, just highlight one of the file members. Please see the attached image for an example.
tdalon
(To:amatei)
Hi
This is not possible:
see also Open file in sandbox view via CLI with file selected
PTC will probably answer you can make a RFC for this feature.
Thierry
2 REPLIES 2
tdalon
(To:amatei)
Hi
Thierry
jszlatki
7-Bedrock
(To:tdalon)
Unfortunately it is still a problem. 11.1.0.961
But.
You can use:
1.) I used this. Unfortunately it is not possible to let display the history up to a defined memberversion
integrity://integrity_server:PORT/si/viewhistory?selection="my file name.xy"&project=/Project_path/project.pj
2a.) I liked better but not used:
2b.) It become fast my favorite:
integrity://integrity_server:PORT/si/viewhistory?selection="my file name.xy"&projectrevision=x.y&project=/Project_path/project.pj
// you have to know in which version of the project existed your needed member 🙂 did not worked by me correctly
PTC PLS: implement the si/viewrevision, what would be great thx.
