Hello team,
I need to know the possible inputs to Windchill Requirements Connector apart from the following
1. Requirement Management tool ILM
2. OLE objects such as MSWord and Excel
Also I need to know if the Exhange file such as DDE (DOORS Data Exchange) extraced from one DOORS database can also be interfaced to another DOORS database or not.
Thank you!!!
Hello team,
Can anyone reply for this query??
Hello Sureshbabu,
Windchill Requirements Connector allows users to collaborate between Windchill RV&S [ILM] and DOORs. It follows the ReqIF specification.
The DDE feature is a proprietary IBM capability that is not supported by WRC.
Kartik
Hello Karthik,
Thank you for the feedback.
So apart from the inputs from ILM, what are the other input files/format for Windchill Requirements Connector?
Suresh Babu
In an ideal scenario, the input from any tool as long as it is aligned with ReqIF specification should work. The actual file package is <file>.reqifz
Kartik
