Presentation Template - dynamic adress for embedded images
jsummers
11-Garnet
Currently the system allows you type in the URL address for the image but when we move to testing there can be no changes made unless it is moved back to a development environment as the audit rules say you do not make changes after testing has been signed off.
Should be able to embed the <%hosturl%> as a part of the link to give the ability to NOT change the URL for moving from Staging to Production.
kjain-2
(To:jsummers)
Hi @jsummers ,
It's very good option but Integrity don't provide this flexibility may be we can say cons here.
But if we are moving our data from staging to production so in that case rather then editing URL for every single image i always do this using Database by accessing related table and edit all the previous URL entries at once.
Vielen Dank / Many Thanks
Kapil Jain
kjain-2
(To:jsummers)
Hi @jsummers ,
Kapil Jain
Found we had stored our images outside the Administration Manuals definition of where you store your images, once we corrected where we stored our images it was just a matter of changing the is.properties file with new server name.
