1) What is process to merge the change packages, while sources branch having the structual changes (for example: files or subprojects be added, moved, dropped, renamed) to destination branch? 2) What is process for 'Apply CP' in mks client?
Hello Mahendra,
I believe the information you are looking for is in CS125580: How to merge two different revision branches to mainline in Integrity.
Kael
