Related Item for Test Result
nborrerojr.
I am trying to create an item that can be used as a "Related Item" in the Test Result Editor. I use the chain link to create a related item. When I try to save it I get the error "Could not save item: Editing FVA: Relationship field References is empty". Could anyone explain this or point me to documentation that explains it? I haven't been able to find anything anywhere on this error.
Nolin
To follow up: The solution to this issue was captured in CS198226.
Thanks for your patience on this one, Nolin.
Kael
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
2 REPLIES 2
Hi Nollin,
Could you contact PTC Integrity Support to have them investigate this with you?
Kael
Kind Regards,
Kael Lizak
Kael
Kind Regards,
Kael Lizak
