I'm wondering if there is a workaround for this error message:
Error editing field Tracker: MKS124205: The relationship field cannot be converted to single-valued since there exists, or has existed, multi-valued relationships on the field.
I had optimistically replied yes to this inquiry:
Convert the field "xxxxxx" from multi-valued to single-valued?
Note that existing items and item history will continue to reflect existing multiple values for this field.
I also ensured that all current values were made single, but the error message seems to indicate that I am still burdened with the history of multiples. I am hoping there might be a workaround other than creating a whole new field. Guessing that somebody has maybe asked this before but I haven't found it in the community.
Hopefully,
Dave
Hello Dave,
Unfortunately, you were correct that the only workaround is to create a new single-valued relationship field and copy the data over.
Kael
