I have tried this for SPR Task in State "Ready to Verify" to close it:
>im editissue --addFieldValues="State=Cancelled" <SPR Task ID>
since SPR Task's field "State" appears as pick field (drop down list)
however, the command fails as incorrect field type used -
"Field "State" is of a type which does not allow the options "addFieldValues"...
Allowed field type are: pick, user, group, ibpl and relationship"
Which type of a field I have to use in the command?
Thanks!
You can set the State field just using the --field option. This is true for State, Project and Type. They look like pick fields, but are actually their own special types.
im editissue --field=State=Cancelled <SPR Task ID>
