How do I get this dialog to show up for a new relationship I defined? My new relationship uses a much simpler box instead that's not as functional.
Here's the one I get:
Hello Nolin,
The functionality you are looking for is tied to the Tests relationship field, and is not configurable to other fields. If you would like that functionality generalized, please contact Integrity Lifecycle Management Support to enter a feature request for that functionality. Please also ask the TSE you contact to circle back and post the RFC number and the KB article for that issue in a follow-up response here.
Kael
Hello Nolin,
Kael
Nolin,
Your request has been submitted as RFC 103496. The article will be available at https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS201972 within the hour. I'll keep you posted on any developments.
Nolin,
I have changed the RFC you are attached to. This request is now under RFC 172079. The article is available at: https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS90200
Is the 10.7 upgrade referenced below related to this at all?
| 117186 | Ability to filter projects when finding a document to open In the Finder dialog box, you can now filter the results that are shown on the left side. In typical ALM configurations, this is the projects list that is returned by the findersettings query. |
