I am using Integrity 10.8.0.8356.
Under File->Preferences->Configuration Management -> Diff and Merge Tools
the user can set the preferred Diff command and Merge command.
For example in the configuration file below
"C:\Users\MateiA\AppData\Roaming\Integrity\10.8\IntegrityClient.rc"
I see the following values:
vdiffCommand=compare.exe /title1\:"{1}" /title2\:"{2}" "{3}" "{4}"
mergeCommand=compare.exe /wait /title1\:"Merge From\:{1}" /title2\:"Merge Base\:{0}" /title3\:"Merge To\:{2}" /3 "{5}" "{4}" "{6}" "{8}"
I am interested to set these two values via CLI
I don't know how to use setprefs --save --command=??? --ui=gui someKey=someValue
Many thanks !
Unfortunately, there is no way to set the Diff or Merge command from the CLI. One can only set this in the GUI preferences or by directly editing the IntegrityClientSite.rc file.
This would be a good Idea.
