Source Integrity APIs
ptc-4667761
What is the list of API integrations that are available for MKS Source Integrity.
For instance I know there is a MKS integration for working in IBM Rational Developer and there used to be a MKS integration for Visual Basic 6. Is there a MKS integration available for more recent versions of Microsoft Visual Studio ? Thank you.
Hi Mary,
Here are the official lists of Integrity integrations (depending on your Integrity version):
http://www.ptc.com/WCMS/files/142568/en/Integrity_10_x_Integrations.pdf
http://www.ptc.com/WCMS/files/142569/en/Integrity_2009_Integrations.pdf
The documents mention that some versions of Visual Studio 2005, 2008, and 2010 are supported
Hope that helps,
Matt
2 REPLIES 2
Hi Mary,
Hope that helps,
Matt
Hi Mary,
we've used the VS integration for 2005/2008 and 2010 for some years now.
There are some things not in the manual you might to consider, depending on the type of projects you develop.
There is is a basic SCC integration as well, that can also be used with Studio.
HTH Matthias
