In the Administration Client, open the Workflows and Documents node, then Configuration and Properties.
In the list on the right, look for mksis.in.SpellingDictionary. Edit this property and add the path to the dictionary file
To ensure all users can use the external dictionary, you can copy the dictionary file to the Integrity Server file system, in the <server_install>\data\public_html directory. Any files in this directory can be accessed using the Integrity Server URL.
For example, the file "<server_install>\data\public_html\En_US.dictionary" can be accessed using the URL "http://<host_name>:<port>/En_US.dictionary"
The dictionary must be a text format file.
Will this give WEB users the ability to have spell check as well?
This depends on your web browser and settings. I can confirm that firefox generally uses its own dictionary.
