Test with Bugs - API
The following c# code snippet gets all tests associated with a bug, but it is super slow and cannot be run in parallel. Is there a way in the WebApi to do the same thing?
private string RunCommand(string bugId)
var proc1 = new ProcessStartInfo();
proc1.UseShellExecute = false;
proc1.RedirectStandardOutput = true;
proc1.CreateNoWindow = true;
proc1.WorkingDirectory = @"C:\Windows\System32";
proc1.FileName = @"C:\Windows\System32\cmd.exe";
proc1.Verb = "runas";
proc1.Arguments = string.Format( "/c " + "im viewissue --showtestresults {0}", bugId);
string result = string.Empty;
using (Process process = Process.Start(proc1))
using (StreamReader reader = process.StandardOutput)
result = reader.ReadToEnd();
return result;
