Windchill Requirements, Validation & Source 13.2 is released and available for download
KartikOak
Windchill Requirements Validation & Source 13.2 has been Released!
Key Highlights for the Refreshed Web UI
  • Test Management
    • Add Test Cases to the Session
    • Mark Test Steps
    • Mark Test Results & Result Fields
    • Create Related Items (To Test Case)
    • Add Attachments
    • User Experience improvements
      • Configure your layout
      • Welcome back to the last executed test case
      • Filter View based on Test Result and more…
  • Items
    • Copy an Item and its field values
    • Copy As with field values
  • Documents
    • Copy or Move the content to another Document
    • Add Documents as Sub Documents
    • Explore & Add vs. Quick Add User Interface
  • Create Relationships
    • Create Related Test Cases from Item View
      • Drag field values from a requirement to a test case
    • Drag & drop to form Relationships
    • Create Related from various Page
    • Create Related with copy fields
  • Customer Feedback
    • Swing Custom Actions in Refreshed Web UI
      • Edit in Word
      • Gateway
      • Document Differencing & more…
    • Set Locale
    • Relationship Viewer
      • Enhanced Export
      • Retain configured columns
    • Mini-info Page
    • E-Signature
    • Server Alerts by the Administrator
Documentation
Download
TIP! The download site has been activated and may take up to 48hrs to start reflecting for all customers. The future flag on the Software Matrix will also get updated shortly.
Register for Brainshark to get a full view of the What’s New if you haven’t already.
0 REPLIES 0
