For example
in older Integrity version the
command below worked correct but failed in Intergrity version 11.1 because of missing local project .pj.
Projectpath=/Projects/Library/LibPart1/project.pj
Sandboxpath=C:\Library\LibPart1
working path cmd-line C:\Library\LibPart1
si viewproject --hostname=... --port=... --nolock --batch --yes -S c:\Library\LibPart1\project.pj c:\Library\LibPart1\*.*
if Sandbox location is the same as project location it worked, otherwise not.
For new versions since 11.1 worked only on sam pathes this
si viewproject --hostname=... --port=... --nolock --batch --yes c:\Library\LibPart1\*.*
error Message:
Checking out...
*** MKS125408: c:\..*.* is not a valid member name.
Can anyone show me a solution how i can checkout the files in the sandboxfolder in version 11.1?
I hope to get help here
Thank you
ingo
@Jaime_Lee Please move this discussion in Integrity forum, here: https://community.ptc.com/t5/Integrity-Questions/bd-p/Integrity
Hi Ingo,
I am a bit unclear of the issue. You appear to be talking about si co command in the title but within your description of the issue you are describing viewproject commands.
Could you please reply with a full description of your issue and could you also please send the full command that failed?
Andrew
Just assuming that you mixed up 'si viewproject' with 'si co'
and there is exactly one (sub)sandbox registered in the path c:\Library\LibPart1>
Im only guessing that you wanted to to something like
c:\Library\LibPart1>si resync --recurse --filter=file:*.*
or
c:\Library\LibPart1>si co --recurse --nolock --filter=file:*.*
or
c:\Some\Other\Path>si resync --recurse --filter=file:*.* -S c:\Library\LibPart1\project.pj
(in all examples --filter=file:*.* is not necessary for an all files pattern)
I would say 'si resync' fits the best for a "standard" handling of the supposed use case
with Integritys Configuration Management.
(You cant forget --nolock here 🙂 )
Regards
Juergen
