com.mks.api.response.APIConnectionException: Remote host closed connection during handshake
ptc-6124669
I keep getting this error when running my code:
import com.mks.api.CmdRunner;
import com.mks.api.Command;
import com.mks.api.IntegrationPoint;
import com.mks.api.IntegrationPointFactory;
import com.mks.api.Option;
import com.mks.api.Session;
import com.mks.api.response.APIException;
import com.mks.api.response.Response;
public class MksMain {
@SuppressWarnings("deprecation")
public static void main(String[] args) {
String host = "";
int port = 7001;
boolean secure = true;
String user = "";
String password = "";
try {
IntegrationPoint ipf = IntegrationPointFactory.getInstance().createIntegrationPoint(host, port, secure, 4, 11);
Session session = ipf.createSession(user, password);
CmdRunner cmd = session.createCmdRunner();
cmd.setDefaultHostname(host);
cmd.setDefaultPort(port);
cmd.setDefaultHostname(user);
cmd.setDefaultPassword(password);
Command connect = new Command(Command.SI, "connect");
connect.addOption(new Option("",""));
Command checkout = new Command(Command.SI, "co");
checkout.addOption(new Option("", ""));
Command disconnect = new Command(Command.SI, "disconnect");
cmd.execute(checkout);
Response response = cmd.execute(checkout);
String resID = response.getResult().getMessage();
System.out.println("Established connection " + resID);
catch (APIException e){
System.out.println("oops");
e.printStackTrace();
Happens after line cmd.execute(checkout);
Any ideas?
Thanks in advance!
1 REPLY 1
Hello Andrei,
In this sort of situation, I would normally recommend contacting PTC Integrity Support to examine this issue, but I see that your account is not associated with a maintenance contract.
Could you supply some logging from the <ServerHome>/log/server.log file?
Are you using additional jar files? If so, are you sure you have the correct classpath to access those jar files?
Kael
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
