customize field-separator in "si viewproject" and "si viewprojecthistory" CLI ?
mnein
2-Explorer
I need to run the commands "si viewproject" and "si viewprojecthistory" to gather information about checkpoints, labels and members (associated to a specific checkpoint/version of a project) for reporting.
The documentation states for both commands: <<Under the CLI the fields are separated with a space.>>
This is only partly correct, since "viewprojecthistory" uses <tab> as separator while "viewproject" uses <space> (optional multiple depending on indent).
My question: Is there any (CLI-) option available to customize the column/field sparator for the output of these commands? The preferred separator character for me would be <tab>.
Integrity-Version (si about):
Integrity 11
Build: 11.0.0.506
API Version: 4.16.506
Hotfixes:
Copyright (c) 2016 PTC Inc. and/or Its Subsidiary Companies. All Rights Reserved.
thanx
Markus
awalsh
(To:mnein)
Using the --format option for si print, you can control exactly what you get, including field separators.
You also have to use -r:member to display only the member revision info, as I found that si print shows all revisions by default.
For example:
si print --recurse -r:member --noHeaderFormat --noTrailerFormat --format="{projectname}\t{membername}\t{memberrev}\t{date}\t{cpid}\r\n"
Will display the project/subproject, member, member revision, date, and change package for each member on a separate line, with the fields separated by tabs.  Since there's no indent or subprojects displayed with si print, I added the projectname field so you know which subproject the members belong to.
The list of fields is found in the si rlog man page.
3 REPLIES 3
kthierer
(To:mnein)
My alternative for si viewproject would be
c:\MySandbox>si print --recurse --revision=:member --fields=membername,memberrev,archivename
where the fields are separated by tabs (at least for my integrity version).
For more control about format you should read in the reference guide how to use
the --format option.
Note that "si print" is using "si rlog" internally.
(I guess: si rlog --NoHeaderFormat --NotrailerFormat --revision=:member --fields=membername,memberrev,archivename)
Regards Juergen
awalsh
(To:mnein)
For example:
mnein
2-Explorer
(To:awalsh)
thanx to all,
now I get the report in a format I like it Smiley Happy
