how to: upgrade Implementer 2008?
jvalle
I need a best practice, how to upgrade Implementer2008 to implementer 12.0. Thanks
2 REPLIES 2
MichaelChatel
20-Turquoise
(To:jvalle)
Hi Jorge,
Perhaps one of the Implementer support folks may come across your post, but I'd suggest opening a Support case with Implementer support, as I imagine the upgrade path from 2008 to 12.0 has a few considerations.
In the interim, some of it is covered in the Implementer Install admin guide,
https://support.ptc.com/WCMS/files/170281/en/ImplementerInstallAdminGuide_12_0.pdf
David_G
(To:jvalle)
Although that is a pretty big version jump, the installer should handle it just fine.
Make sure you have a reliable backup (always best practice when upgrading anything) and do the upgrade.
Personally, I would suggest you do a test upgrade beforehand just to make sure there aren't any problems.
IBM i on Power Systems: For when you can't afford to be out of business! I'm riding in the American Diabetes Association's Tour de Cure to raise money for diabetes research, education, advocacy, and awareness. You can make a tax deductible donation to my ride by visiting https://ptc.diabetessucks.net. You can see where my donations come from by visiting my interactive donation map ... https://ptc.diabetessucks.net/map (it's a geeky thing).
