im createsolution
jhm
im createsolution
Looking for a better definition of the im createsolution [--[no]include Issues] command
1 REPLY 1
awalsh
(To:jhm)
That option is used to include sample data in the solution you are creating.  It will include all the issues created as part of the imt. Using --includeIssues means that when installing the solution, there is the option to install sample data.
