hi,
I'm on version 10.3 and I'm trying to decide if I should go to 10.5 So I browsed for integrity documentation looking for enhancements and what is fixed in 10.4 and 10.5. I couldn't find anything though. does anyone know how to find this infromation ie changelog for integirty 10.4 and 10.5. I didn't see it in the server administration guide or the upgrade guide.
thanks
adam
Finally found it. You need to go to the software downloads section, then download the documentation. Then there will be a folder called relnotes and that has the release notes which lists the new features and fixes.
Hello Adam,
That method certainly works, but you might find it easier to go to the Reference Documents section of Integrity tab of the eSupport portal, and do a browse on Integrity and 10.5 (or whatever release you are considering), then searching for release notes. These links are online links: Integrity 10.5 Release Notes.
Kael
