? mark in front of deleted subproject from the DB, i used si deleteproject thinking to delete fully
sreeckg1
Hello All, i am seeking Help for SI Deleteproject, i used it sucessfully it deleted , but there is ? in from of the subproject which got deleted, i need to fully remove it from the DB so that in future if same name subproject is created it will not cause any error. can any one provide the work areond to fix this?
Not i am admin with app & db server full access. i can run cmd on the DB or app server, pls share your case how the cmd helped you, if you can.
1 REPLY 1
Hi @sreeckg1,
Thank you for your question.
Anurag
