Hi, I am updating an Item using java program but getting "null" response.
Please help me with below code.
Command cmd = new Command();
cmd.setApp(Command.IM);
cmd.setCommandName("editissue");
cmd.addOption(new Option("field", "\"" + value + "\""));
cmd.addSelection(issueId);
CmdRunner cr = getPTCDataSource();
Response response = cr.execute(cmd);
Result result = response.getResult();
It throws "CommandException" saying CommandException(null).
Generated query from the code: im editissue --field="Discussion=API Testing" -- 1234
Please assist.
Gajanan.
I haven't used the API in a while but I'm pretty sure the problem is with the line that contains "field"...
Firstly, the option to add is the command's full option, which in this case uses the syntax fielname = value.
Secondly, I believe you don't need the double quotes.
So your line should be something like that:
cmd.addOption( new Option( "some field name=some valid value for this field" );
Note that the double quotes are around the whole option, and that could have been stored in a string variable.
Yes, you are right. Thank you!!
