removing last commit from history?
tpapendieck
hello,
I'm using souce integrity 2009 build 4.10.0.9049 SP 006/01
I started working on an existing project and as Robert (uncle Bob) Martin suggests I first checked out the code reformatted it and checked back in.
Unfortunately all the other developers are quite unhappy with that approach.
My changes are associated to a ChangePackage, but I commited to main line.
is there a way to remove my commit from the server?
bye
Thomas
3 REPLIES 3
Hello Thomas,
You can't remove a revision from the history (that would defeat the point of having a member history), but you can check in a new revision that is actually the revision just before the one you checked in, based on this article.
Please let us know if that helps.
Kael
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
I cannot access that article, the login page says that my account (my email-address) is not known. Don't you have single sign on?
bye
Thomas
That's odd, since the article is public.  Could you please contact PTC Support to have this investigated?
Kael
Kind Regards,
Kael Lizak
